"She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself."
dane_houston
Car: 1995 300zx TT Vert
1993 300zx Slicktop
1990 300zx TT
Here's my crazy sleeper GTX build. Did 774whp on a Mustang dyno, 831whp on a Dyno Dynamics. Ran into a few problems last time at the track, so I didn't get a clean pass but I'll be taking it to Texas Mile at the end of October for some proper high-speed shenanigans! :shifter:
If you have any feedback, input, or questions, let me know!
MORE PICTURES:
http://imgur.com/a/r6bTq
Mod List:
Engine
- Houston Z Auto cryo long block
- CP Pistons 10.5:1
- Carillo Rods Pro H beam with 3/8 Carr Bolts
- JWT 500 Cams
- JWT Valve Springs
- Ported and polished heads
- Ferrera Viton Valve Seals
- New OEM Crankshaft Cyro treated
- Tial 50mm BOV’s
- New OEM Oil Pump
- EP racing 8 quart oil pan
- ATI super damper 1000hp version
- ARP L19 head bolts
- ARP L19 main bolts
- Ramey Z chromoly timing studs
- H.I. Overdrive water pump pulley
- BDE Adjustable Intake Cam Gears
- BDE Bullseye Adjustable Exhaust Cam Gears
- BDE Low Profile Motor Mounts
- BDE Half Moons
- Houston Z's Full Flow Oiling System and filter relocation kit
- Koyo radiator
- SZ Koyo radiator brackets
- CZP upper and lower radiator hose with lower hard pipe
- Mishimoto thermostat
- CZP heater core hoses
Fuel
- 6AN Aeroquip fuel hose feed and return
- BDE Topfeed Fuel Kit kit
- ID 2000cc injectors
- Aeromotive Adjustable FPR
- Aeromotive fuel filter
- Dual Walbro 485 Ethanol Fuel Pumps
- Dual fuel pump relays controlled via AEM
Intake/Charge
- RobZ’s Billet 62mm Throttlebodies
- K&N 3 inch dual air filters
- Ashspec 2.5" Intercooler pipes
- Ashspec 3" Planar intake pipe kit
- Ashspec Massives V3 Intercoolers
- Ashspec Z Garrett GTX2863 Turbo kit with 3inch v bands inlets
- DEI turbo jackets
- Tial 50mm Q BOV x2
Exhaust
- Ashspec Z Exhaust Manifolds
- SZ 3" 5 Bolt Stainless Downpipes
- SZ 3" Stainless Testpipes w/ dual bungs
- SZ 3" Stainless Resonated X-pipe
- SZ 3" Stainless Dual-oval Catback
Electronics
- AEM Series II ECU
- Apexi AVC Type-R Boost Controller
- Apexi SAFC-II Air/Fuel Controller
- Zeitronix Dual ZT2 Wideband/Controllers
- Zeitronix DashDaq XL II
- Stillen Gauge Pod
- Zeitronix Pressure and Temp Sensors
- HKS Turbo Timer
- Wiring Specialties EFI Harness
Drivetrain
- 99’ JSPEC Transmission
- SZ/RPS High 5 Puck Clutch
- Powertrain 1pc Aluminum Driveshaft
- SZ Stainless Clutch Line
Suspension/steering
- Seam welded, reinforced, and powdercoated rear subframe
- Stock Polished TT rear wheels all around.
- TEIN Super Street Coilovers
- TEIN EDCF Active Pro Controller
- Powertrix Front Upper Control Arms
- Powertrix Endlinks
- SPL Pro Tension Rods
- SPL Air Ducts
- SPL Pro Rear Traction Arms
- SPL Solid Differential Bushings
- Energy Suspension Subframe Bushings
- SPL Rear Knuckle Mono Ball Bearing
- SPL HICAS Lockout Bar
- SPL Rear Upper Control Arms
- Stillen sway bars
- Stock TT rear wheels all around
- Mickey Thompson 255/50/16 ET Streets
- Energy Suspension Steering Rack Bushings
- Energy Suspension Subframe bushings and
- Front Control Arm Bushings
Cosmetics-
- Jspec 1999 tail lights
- Polished Plenum
- Polished Coilpack Brackets
- Polished CAS Bracket
- Polished Throttle Bodies
- Polished Throttle Linkage
- Polished Intercooler Piping
- Polished Inlet Piping
- Polished Water Pipes
- Polished NA Power Steering Reservoir
- Powertrix Fog Light Ducts
- Badgeless Rear and Shaved Nose Panel
Deletes-
- AIVs
- EGR
- PRVR
- Carbon Canister
- Throttle Body Coolant Lines
- Cruise Control
- HICAS
rgregoryb
Car: 1992 300ZX 2+2 NA
But do you have any money in it?
dane_houston
1993 300zx Slicktop
1990 300zx TT
Nahhh.....
DCaff300ZX
Car: .
1993 CRP TT- Modified
Very impressive stuff there sir, congrats!
