shaving the trunk of emblems?
nismodan69
Car: 2007 g35 coupe 5AT sport
i saw a white g with the trunk completely shaved and i thought it looked gorgeous!! does anybody know what i could use to take the adhesive off under the letters?
yerv[g35]
Car: 03 g35 sedan
juss get a blow dryer and hold it against each letter one by one for about a min den use a credit card 2 peel off the letter n if there is any thing left behind juss rub it off
W661335PF
Car: 2004 G35 sport sedan-- Mod money goes to 401K
G paint is extremely sensitive-- the most scratch NON-resistant of any car I've owned, and there have been many threads here and on other forums about this. To reduce the risk of a scratch further, you can also use fishing line to gently "cut" the lettering away in the same manner as described above (with the blow dryer to heat up the glue).
Good luck!
telcoman
nismodan69 wrote:i saw a white g with the trunk completely shaved and i thought it looked gorgeous!! does anybody know what i could use to take the adhesive off under the letters?
I had an old blond girlfriend that was...... never mind
Road Ruler
Car: G35 sedan prem
Back in the ealy 70's my buddy had a 1969 bright red AMC AMX. The factory had put chrome AMX letters on the vehicle. He was a commercial graphic artist and replaced the chrome letters with quality white stick on letters. It was a huge improvement.
On my red G I was thinking of dumping the chrome lettering on the rear for black stick ons.
LOL.. If AMC built the G35 instead of Nissan they could have called it AM-G
chad1200
Car: 2004 G35 AT Sedan
telcoman - FRICK'N AWESOME -
zozoka1212
Car: 08 Infiniti G35x
LMAO
You are too funny.
zozo
2mhighside
Car: 06 G35 Coupe MT
Just before i installed my skyline emblems i removed all the decals. I have to admit i was hesitant to put anything back on it did look awsome. They came off really easy with a blow dryer and a plastic body scraper. 3M makes a really handy little wheel that takes off sticky residue. Its kinda like a spinning eraser it worked awsome. Just dont burn the paint!
pae9132
Car: Modified 03 V35
ok well I live in an apartment and don't have a portable hair dryer (if they even make one) so I used the fishing line...get some line that's about 10lb or higher rated just so you know it won't break....then all you have to do is hold it like dental floss and work your way behind each letter....I never used that 3M rubbing wheel but it sounds like a good idea because I used my fingers to get the residue off and that sucked....when I was done with that I used rubbing compound to make sure it was all of and I strongly recommend using it....when I put on the rubbing compound I was actually able to see the whole "infiniti" and the "G35" until I rubbed it all off...then get a wax on the car for the paint protection...good luck
johnparkyourcar
Car: 03 DG coupe 5AT
did anyone run into problems where the paint would be a different shade then the rest of the area? I would assume the paint would fade over time but if you take the emblems off, wouldnt the paint behind the emblems be a different shade than the rest? that is the only thing thats stopping me from shaving the emblems off my car. but heres another thought... what do you guys think about painting the emblems to a black chrome color?
Rivalry
johnparkyourcar wrote:did anyone run into problems where the paint would be a different shade then the rest of the area? I would assume the paint would fade over time but if you take the emblems off, wouldnt the paint behind the emblems be a different shade than the rest? that is the only thing thats stopping me from shaving the emblems off my car. but heres another thought... what do you guys think about painting the emblems to a black chrome color?
That would only occur after a LONG time frame. For instance, my 99 Dakota - I took the lettering off the side/back with a blow dryer about a year 1/2 ago (it was about 7 years old then) and used some Goo Gone to remove sticky residue after it was all off - no fading or oxidation present. Your G should be fine!
Painting the emblems is an interesting idea, actually. If you can find a professional to do it, I say go for it. Would look awesome!
johnparkyourcar
I've seen some pictures of blacked out emblems on other forums and from the pictures, its hard to tell the difference, but recently I've been thinking about going on a blacked out theme on my car. Its diamond graphite color, and I'm maybe considering smoking out the head/tail lights, the corner lights, and painting my rims black. Any thoughts?
Rivalry
In theory it sounds kinda cool, but I don't think it'd be very practical on a DG color G. Maybe if it was a black or even white.
Of course, that's my opinion.
