rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Tue Jan 16, 2007 5:17 pm
If you really want to do an all out NA motor, get the rods magnefluxed, straightened, polished, and shot-peened. Use ARP rod bolts and nuts. The crank should be also magnefluxed, straightened, and shot-peened. Magneflux the main caps and use ARP cap bolts. Custom balance the entire reciprocating assembly. You should run forged pistons for reliability. JE and Ross both make forged pistons for the KA.
Don't even think of lightening the rods unless you want to blow the motor up.
Early SOHC pistons in a DOHC will give you ~11.6:1 compression. Later SOHC pistons in a DOHC will give you ~11.1:1 compression. That's too much compression to run on street gas. You're going to have to run racing gas which is around 6$ per gal.
