uber240times2 »
https://forums.nicoclub.com/uber240times2-u131663.html
Wed May 09, 2012 11:50 am
What Jared said, but instead of using a fiberglass around the edges of the plastic inserts, use a sandable plastic repair adhesive. It offers strength and it will also allow more flex. I would sand the edges with 80 grit sand paper on both the bumper and the inserts, After this, apply the adhesive to either the insert or the bumper or both. Try not to lift the insert after placing it to avoid air bubbles. Let it dry and then sand it untill level, if it isn't level, a thin coat of fiberglass should suffice. If any minor imperfections are still there, a filler primer should do the job. After the filler primer be sure to seal it so you can avoid the line around the edges of your insert. Hope this helps
