shaved head Q
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
hey guys i recently shaved my head since it warped slightly. Now when i got the timing cover put back on it sat to high so i cut the head gasket on the front cover and siliconed it so it doesn't leak now it sat evenlt and my distributor sits in good(before it wouldn't go in) now would this screw up my timing? A timing light was used to set it right but once it was set it started to stall and had to give it gas but i remembered the pcv hose to the valve wasn't connected so that might make die fast, but even after that with all of the shaving and stuff affect my timing as my car not acting wierd in the feature?? i don' t want to be battling my car in the feature at the stoplight, keeping it from stalling. Another Q how much would the compression raise from stock from shaving the head. I had it shaved about 12 thousands of an inch i could have sworn nissan says the maxium is 13? or no?
silpena
no one? i guess i'll just have to wait and see and tell u a story...
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
no. Your timing will nor be effected by the shaved head. The compression shouldn't go up too much. At least not enough to make your car run crappy. check all your vac lines. Cheack cam timing.
p.s. it's "future" not feature.
silpena
i knew i has some spelling errors. Do you know the maxium you can shave without slamming the valves into the pistion i had about.012 taken off. i hand rotated the cams and heard nothing hit so i guess i'm good or would the rods stretch during load and then ka-boom goes my valves?
Brandon93240
Car: 1993 240sx
If your rods stretch you have more serious problems than worring about hitting a valve.
silpena
i just heard that they do but i didn't think it was right....just wonderig.
wa-chiss
2005 Toyota Sequoia
Well, they won't "stretch" but they do move a tad on the top of their stroke. There is a clearance in the rod journals thats all. we're talking less than a thousanth of an inch. Not going to make a difference.
silpena
cool, i'll tell you guys if i notice any indeference from shaving the head. Right now i'm waiting to get my radiator since my old one was clogged up.
