blazncypher wrote:also do you think it will get better reception then the stock am/fm antennae?
Okay, I'm slightly confused by this question...You're referring to the BMW-style fin satellite radio antenna like this, right? Sirius antenna doesn't replace AM/FM antenna. It's separate. Replacing the sirius antenna will have no bearing on AM/FM radio whatsoever. Satellite radio is entirely different. It uses it's own antenna, AM and FM use their own antennas. Changes to one won't affect the others.Unless something is seriously wrong, though, your sirius radio should get MUCH better (clearer) reception than AM/FM does.
Also, just a niggle, "antennae" is plural. If you want to get super-technical, it is specifically biological plural, such as when talking about bugs. With cars and things you still say "antennas" for more than one. Antenna is singular.
