Of course!Rogue One wrote:Have you tried eBay? Prices range from $14.50 to $22.50.
No, it is just AM/FM radio. No XM or navigation.Qashqai wrote:Does 08 Rogue SL has navigation?
That was exactly my expectation when I ordered the antenna from China for my Lancer and to my surprise it is working very well. Here is the thing, I use AliExpress.com and DealExtreme.com to order items from China but those sites doesn't have an antenna replacement for the Rogue either. Can you provide a link for any of those Chinese knock-offs that you know? please.Rogue One wrote:Sorry, but on your budget you'll have to go with the cheap Chinese knock-offs, and hope for the best.
This is my biggest issue with the OEM antenna as well I will get these shark fins too. Where'd you get it? My Rogue is an Iridium Graphite color. I wonder if they have that color so I can hide the black antenna.Rogue One wrote:Cool! The biggest gripe I have about my factory antenna is the loss of XM signal going through wooded areas, or passing directly in front of large buildings.
Hey, where did you order your shark fin antenna from? Do you have the base model rogue or an SL? I want to order a shark fin antenna, but I have a 2012 Rogue SL with the XM and navigation. If anyone could point me in the right direction that would be truly appriciqted.hawaiiguy wrote:Hey guys,
I'm a new member and Just want to show my shark fin antenna on my nissan rogue 2011
Welcome to NICO!wjreese wrote:Hi!
I just bought a used 2012 Rogue SV. I'm loving it so far. My radio, however, gets lousy reception and it finally occurred to me that my antenna must be missing. I'm attaching a pic of the antenna base, and wonder if you could tell me if the old antenna was snapped off. Is there a way I can fix this?
Thanks!
Bill
It was called X-trail in Asia market (Taiwan, China, Hong Kong, Japan). Not Tida nor Qashqai. Vehicle code is NT32 for AWD, T32 for FWD. Just search NT32/T32 from aliexpress you will find out more items rather than just searching Rogue, hopefully that would help.3d1l wrote:Hey people, I did found one for my father's Rogue!
It even looks better than the one I get for my Lancer, smaller, more stylish and better antenna pattern array. It seems better quality overall. I wasn't able to find one because in China the Rogue is known as the Nissan TIIDA Qashqai. Anyways the antenna works on the same principle, a blank covers over your stock base where you have to screw a cable that connects the antenna. With my lancer is working just fine. Let see when it arrive if it works as good with my father's Rogue. I will keep you post it.
Total cost was $23.00 with free shipping.
That is correct...Mopar_Ray wrote: thinking I may have to remove the headliner to replace the base?
Thanks, Looks like a an lot of stuff has to be removed? I may call a dealer, I am worried about breaking any goofy clips that are holding interior parts in.04pathse wrote:That is correct...Mopar_Ray wrote: thinking I may have to remove the headliner to replace the base?
Go to page 222
http://www.nicoclub.com/FSM/Rogue/2014%20Rogue/AV.pdf
Merged with open thread on antenna replacement.Mopar_Ray wrote:Anyone replace a antenna base on a 2014 Rogue? My daughter had her antenna mast snapped off in a car wash. It snapped off the the screw that screws into the base. There was not enough of the screw left to grab on to to remove. I tried to remove screw with a left hand drill bit and only managed to ruin the threads on the base. thinking I may have to remove the headliner to replace the base?
