shaky steering wheel at high speeds?
direktdrive
Car: Nissan S14 - Zenki
So today I finished installing my new tension rods and took my s14 for a spin. When i hit about 70 mph and over, the steering wheel was pretty shaky. Anybody know what might be the problem? Tires not balanced?
adrianfromthecastle
Car: 1992 Nissan 240sx
sounds like tire balance issues.
direktdrive
Thanks adrians_s13.
I'll probably take care of balancing my tires this Friday at the auto hobby.
Then we'll see if that fixes the problem. I think it will. The only other problem I could think of is that my wheels are bent, which seems very unlikely.
adrianfromthecastle
direktdrive wrote:Thanks adrians_s13.
well, hopefully when you get your tires balanced, the guy will tell you if theres a bend in any of the wheels.
also... if your tires a pretty worn out or has flat spots... theres really not much they can do to balance it. At that point, you might just need new tires.
direktdrive
well my tires are pretty new so i don't think i need new ones.
out of curiousity, could unbalanced 'rear' tires cause shakiness in the steering wheel?
steering seems more dependent of the front right?
adrianfromthecastle
direktdrive wrote:out of curiousity, could unbalanced 'rear' tires cause shakiness in the steering wheel?
no...
lol.. hell, I almost never get my rears balanced unless I really need to.
