NISMOdrift240 wrote:Sorry, gotta disagree guys. Going off what he said... "shakes above 50" thats wheel balance. Sometimes all you have to do is hit a bump and one of the wheel weights will fall off. Just take it into any tire shop and they will balance them for ya for cheap.
Tension rod busings when they fail, make the steering wheel wobble a little when you change lanes. More of a loose feeling up front. I know this cause mine are toast. Got some Energy suspensions coming from Courtesy Nissan. Dont buy from them...its been a month, wont see them til next week.
dont make me hurt you. my T/c bushings didnt vibrate till over 80mph. I work at a wheel and tire, suspension, etc place. Its very possible thats his problem, here how to trouble shoot it:-Check your tires for odd wear patterns, etc.-check ballancing(its cheapest) of wheels(also check to see if you have hub rings on your aftermarket wheels, if you have them)-look at you t/c bushings-Check for any other suspenion bushings worn/missing
allignment rarely causes a vibration problem, it can cause odd wear patterns in a tire that LEAD to vibration, but I'd recommend checking it anyway.
-chet
