Shaking Z32!!
SlidewayZ32
Car: 1990 Z32 NA
Greetings Nico!I've recently put my top manifold back on and as I start my car for the first time in a couple weeks,she shakes!!It's abnormally hard of a shake,and then I get an Injector Circuit(Code 51)...Before pulling the plenum,I saw that there was a good amount of corrosion on all of them.What's the best way to clean the prongs on both the connectors and injectors??I'm trying to keep getting 6 new injectors my last resort! :frown:
NolimitZ32
Generally, using a small wire brush on the injector and de-pinning and using the same brush on the connectors is best. if you can't or don't want to de-pin the connectors you can dip each on in a small container with a baking soda and hot water mixture, this neutralizes (eats) the corrosion but is definitely by no means as effective as physical cleaning.
SlidewayZ32
Car: 1990 Z32 NA
Okay I'll give that a try.Thanks for the information!
