mesallem wrote:hey guys,
have a quick question, when im driving and i come to a stop light the car starts shaking, if i put it in neutral, the shake is still there but not as severe as it is in drive, i first suspected the motor mounts but then thought it could be injectors, does anyone have any experience in this? also i kept getting the tail lamp inoperative message and as per reccomendation, i changed most of my bulbs with the long life bulbs, the message went away for like a week and now its back and one more question, how do i get rid of the brake pads worn message?
Are all cylinder's firing okay? What is the idling RPM? Could also be bad MAF. Try wiggling the connector on the MAF.
For tail lamps, are all the lamps actually working? Have you had someone stand behind and observe? Sometimes the bulb sockets are worn or have a crack. Did you change the bulb in the third light in the rear deck? Use dielectric grease on all... available at any auto parts center. I have a set of like-new 95' bulb sockets if you end up needing... they are just below the instrument cluster in this pic. I'll apply dielectric grease before shipping if you are interested.
zer...age=1
For brake warning issue, you can cut the wires going to the sensor (on the pads) and short them together. These are only on one side of the car. (I forget which).
