Godzillarb26dett wrote:TurboKA at thsi point in time with low horse power you really dont have to go all out and try and upgrade to brembo....the 300zx tt brakes is a good move....
One more thing, sunshine. A car's brake system is not, I repeat NOT determined by engine's power output. Sick of seeing people saying "do this, based on engine power numbers." Bogus!
Meaning, Nissan does not sit down and say, "oh gosh, how much power will the engine produce? because then we must fit brakes to slow down the car with high horsepower output??" No, what they did take into account is how much the car weighed, what speeds it will attain, and how much money it will cost to fit an applicable braking system.
MASS, weight, roll center, combined with a given project budget are determining factors in what brake systems are fitted to what cars. Not the available horsepower. What engineers DO ask themselves is "how can we efficiently slow X amount of weight down from X speed consistently, and do it within our budget?"
There <is> a relation that we can see in today's performance cars between a powerful car that handles well and it's braking ability, but to assume that the reason you upgrade your brake system because you are upping power output is bogus...intellectually sloppy argument. I've seen many people use the statement that if you're upping power, better improve braking. People fail to understand why they need to upgrade the brakes. It's not because of increased power output, or removal of limiter...which will net you greater MPH....but still negligible speed gain when considering that the amount of time spent braking is all that matters in this case. The reason you upgrade your brakes is to improve braking response/stop quicker. The ability of the car to slow down from a given speed depends on the braking system, not the engine output.
Godzilla, I can overheat a Z32 braking system just as quickly as I can a 240 brake setup. So could you.
Power output is an altogether seperate function from braking. Braking is the attempt to slow the car. The lighter(less MASS) the car, the less work the brakes do to slow the car. Clearly, an upgraded brake system will improve braking response, but it's still damn foolish for people to give the reason to upgrade the brakes "well, you're increasing HP man, better fix yer brakes up to deal with all that extra HP." They are two different functions of the car!!!
Use common sense, consider the "how" and "why" next time....not just what you assume to be true, or what sounds correct, or what you tried once or twice.
