shaking when starting
michelemabelle
Car: 02 nissan sentra gxe
My car starts shaking about every other time I start it. It goes away if I rev the engine. After it stops shaking, the car runs fine the rest of the time. It was doing this 2 months ago, then stopped after I got new spark plugs, and now it's starting again. I was wondering if anybody knew off the top of their head what this could be. Thanks.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
What RPM is the car idling when it starts shaking?
michelemabelle
my car's RPMs always vary. but usually when i first start it, its about 500 when its idling. the RPMs are no different if its shaking when it starts, or not shaking.
RED_DET
Vendor
2011 Infiniti G37x
Sounds like the idle needs to be adjusted. It should idle higher than 500. More around 750-800 range. This on the 02 sentra?
michelemabelle
yep 02 sentra. and today it actually idled at 0. but thats never been abnormal for my car. it has idled between 0 and 500 since i got it. but is that why its shaking??? thank you
RED_DET
Vendor
2011 Infiniti G37x
That is part of the reason it is shaking, but you must have a vacuum leak or something is off. TPS or MAF.
SilverB15
Car: 02 Sentra SE-R
I had the same problem, is it like a weird vibration just when the starter is engaged and the motor is nice and still warm??
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Worn motor mount?
SilverB15
Car: 02 Sentra SE-R
I never thought of that....thanks!!! I might check that out - whats a good spot to pick up aftermarket mounts and how much labour would be involved (sorry for all the questions)
