Shaking when braking at high speeds
fernandoh
Car: Pathfinder 2004
Usually the truck is fine in the brakes department (new front pads, good rear linings). Totally normal in city driving. But on the highway, say over 100 kph up to 120 kph (80 miles) sometimes I feel a vibration when I push the brakes during normal circumstances and in straight line. I tought it was the pave but not really as it changed and the vibration is present in any surface (tar, cement). I mean I did not panic stops and that kind of braking, just normal but fast de-acceleration. Any ideas?.
01silvapathy
Car: 2001 Pathfinder LE 3.5
Sounds like a warped rotor to me
alexf20c
Car: '00 SE 4x4
maybe you shouldn't drive 80mph then. just a thought.
ugharin
Car: 2000 QX4; 2002 QX4
If the shaking is only associated with braking, then its almost certainly a warped rotor as already mentioned. The new pads are gonna wear out quick..
If the shaking is associated with the high speeds (60mph+), your wheels are out of balance.
