shaking rear end.. any ideas?
wanka125
Car: 1990 300zx
whenever i stomp on the gas, in between 3/4000 rpm the rear end shakes like crazy. any ideas what this could be? just a U joint issue or whole driveshaft? any help appreciated.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
carrier bearing, subframe bushings, cv shafts, wheel bearings, tie rod ends, lots of possible causes
Cyman
Car: 1990 Nissan 300ZX TT
1996 Honda CBR 600 f3
1995 Chevy Corsica (lol)
I've also heard of something like this coming from a malfunctioning HICAS system, assuming yours is a TT. you'll just have to narrow it down.
wanka125
Car: 1990 300zx
mines a N/A. Im assuming its somewhere in the drive shaft wether it be a U joint or the bearing. I just wanted to know if anyone else had similiar problems.
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Shifted belt in a tire, loose wheel maybe a wheel out of balance.......bent axles.....etc. Could be a lot of stuff.
evildky
06 Nissan 350Z GT
the carrier bearing is by far the most common problem, but there is no replacment for getting under the car and inspecting the condition of all the parts
rizzo2008
Car: 1990 300zx na
Mine does a wheel hop type of thing when i get on it going around left corners. It's pretty violent. I've done a lot of reading trying to find something similar and it pointed to shocks. I haven't replaced them yet because the car drives fine otherwise. It's on my "to do" list though.
evildky
06 Nissan 350Z GT
when the rear shocks go it've very noticible ont he interstate when you hit an expansion joint or other bump, the back kinda skisp around, severs wheel hop when taking off is a sign of subframe bushings
