MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Wed Oct 02, 2002 10:36 am
Sorry, this is a rather LONG post....My 95 240 shakes a lot more than I'd like it to, and it's not my driving style. It shakes when you put your foot on the gas abruptly (while it does have good "throttle" response...it shouldn't shake this much), and it shakes when you take your foot off the gas...for example, first or second, I just blip the throttle and the thing shakes pretty bad. Please don't respond and say that its normal, because no car I've ever driven shakes that much just from stepping on the gas/letting off of the gas. In addition, the car shakes even when its idling....a noticeable amount...I've heard this is the knock sensor? The last time I was under my car,I shook the transmission/engine to see how solid it felt, and it felt decently solid. At first I thought that this shaking was from my clutch needing to be replaced, ie, whenever I up or down shift, the car shakes a good amount, sort of like I'm thinking an older car would that needs to be heel-and toed when downshifting...a 1995 car shouldn't need heel and toe just to make a smooth down****. For example, if the car's in 3rd and I shift to 4th, I let out the clutch pretty slowly so as not to be abrupt, and the car still shakes a good amount. My shifter too, the actual shift knob vibrates A LOT during riding, and other people I know with MT's don't have the same problem at all. Do I have worn motor mounts? What about the TC rod bushings?
Now, onto braking. Past 45 mph, if you put a good amount of pressure on the brakes, the car shakes horribly and the wheel vibrates almost out of control, and the brake pedal pulsates too...it does the same thing if you put it neutral and come to a stop...the car feels fidgety and the brakes feel like they work in "installments" Definitely DOES not feel like a 2750 pound car with 4 wheel disk brakes...A friends heavier honda accord has brakes twice as good, and even minivans I've driven feel like they have better braking characteristics! Now come on, I thought this was a sports car! The fidgety feel of the brakes I think is coming from either warped rotors, as they haven't been replaced in 91 k miles,(they don't feel grooved, however,) or bad brake pads, or both...please don't tell me its actually the caliper doing this? Now, onto questions you guys (and gals!) can answer. If I replaced the front rotors with better, new, cross drilled rotors like what they sell at heavythrottle or pdm, and along with it I replaced the pads, would the brakes feel any better? Would this alleviate the shaking under braking pressure? What pads and rotors do you suggest for someone who likes to "drive his car spirited" and will be most likely auto x-ing in the near future? I've heard HAWK HPS are good, but I need pads and rotors that will be good for every day short trips, like going to school and back, so I need pads/rotors that don't need to be heated up to an insane heat to stop quickly. The pads also shouldn't emit a lot of brake dust and should be durable and good in wet conditions.What rotors does everyone suggest? Should I replace the front and rear, or just the front? Are replacing rotors/pads something somone like I could do with barely no brake experience but with the use of a service manual?If not, how much would a shop charge to replace rotors/pads on the front? It doesn't seem like it's THAT hard to do...Please bestow upon me infinite wisdom, I want to get rid of this crappy braking and shaking!:help
