shaking problem
mxkilla450
ok i just got an alignment done on my 96 s14 front and rear , and the fronts fine and the rear feels fine .only problem is when i jack up the car the toe rods not tight but once i put it down its like rock solid. what should i do ? should i tighten the rod to the point that there is no wheel shake?
