I am now at a blank so any information is greatly appreciated.
I am assuming you are feeling a shake in your steering wheel, and not in the seats. To eliminate the front wheels/tires as a cause of steering wheel shake, rotate the rear tires/wheels to the front & see if it goes away.nbryan432 wrote:ok, the tires are new, just change them with a new set of rims as well. But I am going to have them check on the other components. i am planning on getting a new suspension as well but I need to eliminate this problem first
steve_c wrote:I am assuming you are feeling a shake in your steering wheel, and not in the seats. To eliminate the front wheels/tires as a cause of steering wheel shake, rotate the rear tires/wheels to the front & see if it goes away.nbryan432 wrote:ok, the tires are new, just change them with a new set of rims as well. But I am going to have them check on the other components. i am planning on getting a new suspension as well but I need to eliminate this problem first
