naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Sun Jun 12, 2005 10:28 am
Well as far as the excessive tire slip, thats usually a problem with any rwd car in wet weather, unless you have some really good tires. My car probably spins the tires even easier cause it has alot of weight removed from the back. any way, the bouncing could be caused by above reasons, or a blown strut. My friends jetta used to bounce bad on launch when the tires started slipping, and it turned out the strut was blown, causing poor damping.
