shaking and idle's low
GrEy240SX
Well..my 90 240sx is shaking when its idle. plus when it is at idle the rpm's is at like 100-300 which is really low. and today when i stopped at a red light the car shook alot and rpms at 100 and then it died on me. The battery light is on in my dash so i probably need a new alternator cuz the belts were fine when i checked. If i changed the oil, new alternator, and maybe battery and spark plugs..should this solve my problem?
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
definately wouldn't hurt a bit. might as well do an entire tune up.
Syntax360
Car: 1986 Nissan 300ZX Turbo
low idle because of alternator? doubtful....my alt went out and the car was idling high as it was dying.....mine used to do similar things because it was (and still is :-\) running rich.......get a fuel pressure reading and see if that's nominal. I replaced my FPR, O2 Sensor, and plugs and it did wonders for awhile......prolly cost ya $150, but couldn't hurt anything but ur wallet :-P
nissanrcer240
Car: 90 Nissan 240SX SR20DET
GrEy240SX wrote:Well..my 90 240sx is shaking when its idle. plus when it is at idle the rpm's is at like 100-300 which is really low. and today when i stopped at a red light the car shook alot and rpms at 100 and then it died on me. The battery light is on in my dash so i probably need a new alternator cuz the belts were fine when i checked. If i changed the oil, new alternator, and maybe battery and spark plugs..should this solve my problem?
i have the EXACT same problem with my 240, i never got it fixed but i was told that it was the AAC/ACC (forgot which one) valve...i think it was AAC valve, anyone feel free to correct me;) ....when you do get it figured out and/or fixed be sure to let me know
GrEy240SX
where's the AAC/ACC valve at? i'll have to check that to see if that's it.
nissanrcer240
this should help you out:
click here
GrEy240SX
haha thanks. so should i replace that?
GrEy240SX
or make sure it's on right?
nissanrcer240
i guess you just gota clean it
89240sx
could his tps also cause something like this? or mafs?
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
i got a tear in my intake piping boot (for lack of a better term) and thats messing up my air/fuel mix and it is doing all that jive of low idle running rich.
