http://www.discounttiredirect.com/roadForce.html
http://www.aiag.org/projects/project_li ... tmlgetting to be such a problem that bar code standards might be in place in 5-10 years.
GM is having such a problem that they are dropping from 15 pounds to 9 pound spec on some lux cars.............the Hunter 9700 has an accuracy of 2 pounds max to min force deviation and 0.5 gram weight selection!
"Ironically, developing it has put Hunter Engineering in the midst of a controversy with at least two major tire makers, as well as companies marketing competitive wheel balancers who claim their machines accomplish the same result without the ability to measure force variation.
At first, the GSP 9700 seemed to be welcomed by tire and auto makers alike. Goodyear, for one, purchased a quantity of the machines for its company-owned stores. But the tide of opinion changed dramatically after users of the machine began rejecting and returning non-uniform tires to suppliers for adjustment.
Goodyear and Michelin North America Inc. since have stipulated that data generated by the GSP 9700 will not be accepted as the basis for tire warranty claims.
Michelin said: "This type of machine" (the GSP 9700 was not mentioned by name) does not have the capability to accurately measure and determine tire uniformity, but does have the capability to optimize ride performance in the tire mounting process by properly measuring the tire-wheel as an assembly and offering a match-mounting preference."
For his part, Mr. Scribner said that while he takes issue with Michelin´s statement regarding the GSP 9700´s alleged inability to accurately measure tire uniformity, he doesn´t blame Goodyear and Michelin for taking such a stand.
"I can prove the machine does correlate (with tire industry standards for uniformity) very, very well when it´s used properly," he said. "But in the wrong hands it can be a nightmare. I wouldn´t want to open the flood gates for every tire shop that sends stuff back just because they bought a machine.
"We´ve created a piece of equipment that is revolutionizing the industry. But as a result of unintended consequences of people using the machines improperly, it´s creating a lot of questions along with the answers it´s (providing)."
Revolutionary or not, the machine is only as good as the person operating it, he said. "You have to have someone who´s willing and able to be trained to use the machine properly and who understands the big picture. We don´t want people using the machine as a screening device."
A happy guy who solved his problem after the dealer tired 17 tires to fix a bad wheel problem:"The initial checks showed that I had two wheel/tire assemblies that had real high road force variations. One was over 80 pounds and one was 60 pounds. The tire with the 80 pound reading was found to be defective and had to be replaced. After the work up all the tires now range from between 25 and 35 pound of force variations. This greatly improved the ride of the truck to a point it was acceptable. It is not perfect. The interesting thing was the operator told me that I would still be able to feel a slight vibration in the truck as anything over the 15-20 pound range can be felt. He told me this before the tires where remounted on the truck. He was right.
The only way to make it perfect is to put better tires on the truck. It came stock with Goodyear Wranglers and I hate them. I cannot wait for them to wear out so I can replace them with the Michelin LTX. He said that the LTX is consistently the best truck tire they have seen with the normal force variations at a consistent glass smooth 6 pounds.
The Michelin tires on my Maxima finally wore out after over 80,000 miles of use and had them replaced with, of course new Michelins. On the way home from the tire store I noticed a vibration in the car that has never been there. I took it back to the tire shop and had them rebalanced. Not much of a change.
I then took it to my friends shop and had them balanced on his GSP-9700 and the car was back to glass smooth. "from
http://www.gadgetonline.com/vibration.htm
