rudy543us »
https://forums.nicoclub.com/rudy543us-u38584.html
Wed Oct 28, 2009 1:18 am
You said even if the car is in park, that means the car is standing still?
That makes no sense, what speed does this occur?you said park so I assume this is automatic?Does this happen in a strait line or in a turn? were was the car damaged in the accident?
Shock, springs, axles and bushings:1. check to see if your shock is weak or bad2. A drive axle will be a lot more violent, especially on a 240sx.because the rear diff is stationary the vibration would shake the whole car.3. rear drive axles man that would be amazing I have seen 300,000 on a pair and they were still good.
The Tire & wheel:1. If the tire bounces or shakes at a certain speed try balancing it, 2. If this has been done, Is the rim bent or dented in any way?a bent or dented wheel will balance but that does not mean it will go down the road just fine.4. If it still bounces take it to a different place like sears ask them to check to see if the tires are out of balance, the other shop may have made a error.
Good luck.
