SH***Y gas milage?
tricktunes240
Car: 1992 240sx fastback
Hey ive had my 92 dohc for about half a year with basic bolt ons...i,h,e, high flow cat.....and my gas milage is worse then a hummer H2....one of the reasons i got a 240 was kinda lookin for the 4 cyl gas milage...with the way gas is these days i was wondering if anyone knew some ways to fix up my gas robbing 240.....
Ezzo
how bad are we talking here? from what I remember reading before the H2 gets 13mpg you should be geting 22-27mph with your 240. maybe a little lower due to age.
When was the last time you checked or replaced your fuel filter? Checked for leakey o-rings? Dirty Air Filter? hows the maintenance record on your 240?
SeanC
Car: 1993 240sx SE
i get 23 everyday half in-town half highway. on my way to california i got 30 mpg consistantly.
rsmithdrift
Car: 1993 240sx fastback se.
I get 28mpg half city, half highway. I have an intake, Hi-Flow Cat, NGK plugs + Wires, Elect. fan, 300zxTT fuel filter and that's it.
When I got the car I was getting 19mpg. After I replaced the 02 sensor I was up to 22. After the NGK's, coil, cap, rotor and fuel filter I was up to 23, after the elect. fan I was up to 25, after the intake and hi-flow cat I am now up to 28mpg.
CTS, MAF, 02, plugs + wires + cap + rotor + coil, dirty air filter, pluged cat/exhaust, and vacumn leak are common problems that cause bad gas mileage.
tricktunes240
great thanks for the info thats good info ill try getting some plug wires and O2 sensor becasue everything else that you mentioned i have new so ill see what happens....
thanks
zer0c123
Car: 1993 Nissan 240SX Hatch
Are your smog components still there, like the EGR?
tricktunes240
My egr is definelty removed.....well at least from my exhaust and plugged with a silicone gasket....
discopotatoe
Car: 1990 240sx..SohC
idk about over there but in hawaii gas is over 3 bucks a gallon...i noticed with both my ka and sr...i only get about 20 miles to the gallon...removed emssions...changed fuel filter...nada
tricktunes240
i think im just gonna really have to go easy on the throttle thats the only way? Anyone suspect injectors?
InsanityInc
tricktunes240 wrote:My egr is definelty removed.....well at least from my exhaust and plugged with a silicone gasket....
Do you mean the EGR valve is just sitting on the intake manifold with nothing connected to it? That will cause a vacuum leak, assuming you still have the vacuum lines connected to the valve.
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
tricktunes240 wrote:i think im just gonna really have to go easy on the throttle thats the only way? Anyone suspect injectors?
worst i have ever gotten was 24mpg (93 240), thats all city driving, with a few bolt ons. i would say there is more to it than you just getting on the gas.
as for injectors, i have never had a bad one, but it is something i imagine you would feel (like a miss?)
i used to work at an emission testing place and learned to feel when a car was miss firing, always failed too
tricktunes240
No no there isnt any vacuum leaks at all i properly plugged any holes and lines....there is no leaks from what i know which is basics but i can still nig rig some stuff....any other suggestions?
