trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Tue Apr 22, 2003 7:29 pm
Mad gas mileage is any of the following1) Bad O2 sensor2) Bad Coolant Temp sensor3) TPS4) MAF5) AIV6) Bad injectors7) Bad Injector Seals8) Bad FPR (fuel pressure regulator)
Any of those things could cause it, although if you can smell it running rich you can rule out injector leaks. Start testing things and crossing them off the list.
