Severly corroded window buttons
SynisterQ
Car: 1994 Black on Black Q45
Hi Everybody,
I've noticed 4 or more of my window buttons are rusted and or the paint is starting to fade on them. Back in the day, we used to use a hammer and chisel to carefully remove them. Does anybody else have a better way to remove them? Perhaps cut a deep groove in the center with a Dremel tool and then use a huge flat head screwdriver to remove them? I'm thinking they might be extremely corroded underneath where they're threaded so it might be too risky to even try to remove them.
Q45tech
Common, cut slot use small flat thin screw driver, replace with new.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hmmmm......thought 1994 and later had the newer non-corroding ones.
Early ones were bad.
qship96
Car: 1996 Infiniti Q45
On my 96Q, 2 of the buttons have the paint flaking off due to rubbing against the rubber molding when lowering/raising the window.
They have been like this for about 2 years, and they are NOT rusting at all,even though the metal is showing, and here in Md we do get snow/salted roads. One day,I will sand and repaint current buttons
SynisterQ
qship96 wrote:On my 96Q, 2 of the buttons have the paint flaking off due to rubbing against the rubber molding when lowering/raising the window.
Thank you for the responses. I was thinking of doing the same thing Qship, I doubt it would be too hard. Depends on the price of the new buttons of course.
