wouldent a bad knock sensor throw a code ?iam only getting P0171 & P0174NutriaforBreakfast wrote:Test the knock sensor and check the timing
i know its predetonation, its severe if i try to go up a hill, i can hear the pistons rattling like crazy, i have to go really slow up a hill so it dont ping.iam at wits end trying to solve this.NutriaforBreakfast wrote:Maybe, but it sounds like you have predetonation in your engine,very serious. Would do anything to resolve this
Iam going to test the knock sensor tommorow, The maf and air filter i are new so thats not the issue, also its not running rich, its running very lean. Ill post my findings about the knock sensor and go from there. someone told me it could be the O2 sensor back by the firewall, what are your thoughts on that ?MinisterofDOOM wrote:Well, the problem has to be that either the engine isn't corrently adapting to prevent knock, or it isn't ABLE to because the knock is outside it's adjustment parameters. So either you have bad knock sensors, or you have something like a leaky injector as eikon suggested that's causing detonation the engine can't compensate for. Could also be a sensor issue (like MAF) or a seriously, horrendously dirty air filter or another air restriction that's causing the car to run very very rich.
Timing is good, i added 2 bottles of fuel injector cleaner to see if anything happens,so far so bad.....NutriaforBreakfast wrote:Sounds like the engine timing is too far advanced. Have you checked this?
When i had the intake off and replaced all the gaskets as i stated in first post,i cleaned the egr tube, it was blocked, I dont burn oil, i use the NGK 7090 plugs.I did the spray around the intake and i had no issues there.asand1 wrote:Does the 2000 have EGR, or did you delete your EGR? Having a plugged up EGR or deleted EGR will cause higher combustion chamber temps. Do you burn ANY oil? Carbon deposits are the result of burnt oil and will plug up EGR or deposit directly on piston heads or Combustion Chambers and act like a glow plug. How hot are your plugs, you could try a colder range. Don't know the part #s off the top of my head, but I know where I might get them. A bad knock sensor will cause the ECU to fully retard timing, so Bad KS wont be likely. Use a can of carb/brake cleaner and check for vacuum leaks around your manifold and intake plumbing. that would cause a lean condition and detonation.
WRONG, its 470K, color code yellow, violet, yellow, gold. Radio Shack # is 271-1133. package of 5 is only $0.99. Disconnect the KS sub-harness near the LIM/UIM joint, and insert in female terminals. Then clear Codes.Professor` wrote:So i was reading threads and found that a 550k resistor is a temporary fix for the knock sensor, is this advisable? I got the resistor, i only want to do this because of the high cost of the sensor and its location, i just need time yet before i can do this.
Thanks for the info, i tried this setup and i still got pinging so iam going to rule out the KS as the main issue, i really dont know what else to do. iam just going to install a new fuel pump, fuel damper and fuel pressure regulator, if it still does it ill move on to the injectors, and if it still does it ill set it on fire.asand1 wrote:
I am currently running this "mod" cause I'm cheap. It does detonate with Regular, but I haven't heard anything running Premium.
HOWEVER, you need to find out why you are pinging. A bad KS will retard your timing, and in that case you would then have NO pinging. Your pinging is caused by a problem with the engine NOT the KS.
I am having a similar issue with my 2000 I30, did you replace the KS in addition to the MAF? I have cleaned my MAF several times as well as replaced the plugs.Professor` wrote:I just tested the knock sensor, i found a open circut, So i need to replace the sensor............................ pain in arse because i have to remove upper and lower intake manifolds..........
