I thought the q45 was overkill. Im at 12lbs, pt 60-1, and 351 whp. Very inconsistent running through the rpm. SAFC correction was bouncing all over the place. Plus I got the Power fc, and wanted to put on the z32 to get it to work easier. Power FC doesn't even fire up my car at all, and we chased down some Maf wiring problem at the ecu, but now I can't even get it to idle when a MAf (either one is hooked up) My ecu for the rb25 is stock and I can't pull codes off it, b/c it doesn't have an led light or dial, and I have an extra rb25 ecu with the diag setup, and it won't even fire my car either.Shocker wrote:oh dear.... crank pulley bouncy? is it rubber?
Tighten your alt belt..... should fix the squeal, or get a new belt them re tighten.
why are you switching mafs?
We changed the Maf settings and nothing. Then fooled around with injector latency, and got nothing but raw fuel smell. I was told the injectors were plus sized (rebuilt) stock 370 JECS injectors.Darius wrote:The size of the MAF doesn't have anything to do with the issue. It is all in the calibration/tuning. With the PFC did you change the MAF settings to Q45 before trying to start it or did you just plug it in and try to fire it up?
Werd this is really weird....seems the tuner doesn't know what he's doing.The messed idle could be boost leak or vacum leak related.JPsNissans wrote:So you're running a bigger turbo and 351 whp with stock injectors.
Yep..PN of the purple jecs came back as 370. This car has gone through so many hands, and now im gonna get it right. But prev guy thinks they are 660, or 550, just rebuilt aparently to those specs. When the car is down, Im sending them off to RC find out for sure.JPsNissans wrote:So you're running a bigger turbo and 351 whp with stock injectors.
So is this why the Power FC I bought won't fire up my s2 harnessed rb25. I took the safc 2 out before trying power fc.Part #'s were the same for S1, and S2, but different for Neo right?Carl H wrote:this thread makes my head hurt...i dont understand why you need to pull fuel with a larger maf when the opposite should be true.sounds like you have some wiring issues and if its only got one blue relay its a s2 motor/harness and you might be trying to fire it up on a s1 ecu which wont happen.
The whole skepticism on Q45 MAf downgrade was when I looked at the plug. They hacked an additional silver wire into the ground wire. The original copper black went to nowhere. But when joined in at the harness it went to the white.Carl H wrote:perhaps the injectors were modified, if that was the case then they can potentialy flow 600+cc...but without pulling them and flowtesting you wont know for sure.as for the pfc not firing up the engine thats awfuly strange as the r33 pfc is the same for both s1 and s2 motors, i was refering to s1 and s2 stock ecus...you can use a s2 ecu on a s1 motor but not vice versa.
