aez987 »
https://forums.nicoclub.com/aez987-u27583.html
Tue Apr 05, 2005 4:33 pm
We have a 1997 Q45t. A few weeks ago the car began to stutter and stumble. Shortly afterwards, the Check Engine light came on.
We took the car in to Infiniti for service. The Service Technician told us that the #1 coil pack was bad, plus it was time for new spark plugs. In addition, he suggested that we replace all 8 coil packs, because once one goes out, they tend to fail one after another (I never heard that before, though). Anyway, all eight coils would have cost over $2000!!!
As a result, we had them replace only the #1 coil pack and all 8 spark plugs. The car ran fine for about 5 days then the same thing happened - Check Engine light and stumbling.
So, I looked under the hood and there was an ENORMOUS collection of corrosion on the battery terminals. I replaced the positive terminal and cleaned up the negative one thoroughly. In addition, I put on a new gas cap. So far, after 2 days, it's been okay. My questions are:
1.) Is it likely that all of the coils are starting to fail?
2.) How can I test the coils to see if they are okay?
3.) Is this a common problem with the Q, if so what is the normal remedy?
4.) Would the corrosion on the battery cables have increased the resistance so much that it threw off the car's electronics?
5.) Finally, how do I remove the front lens cover on the driving lights? I want to remove the 'glare guard' like I did on my 300ZX. I know how to replace the bulbs, but can't seem to get the actual lens off even after removing the clips.
Thanks in advance for your patience, and for any assistance you may provide me. Take care.
