rnvateeo »
https://forums.nicoclub.com/rnvateeo-u104880.html
Tue Sep 30, 2008 6:53 am
well, i'm sure glad i listened to your advice/s.
I've ended up with an 01 q45t, just turned 100k. I LOVE this vehicle!!
some minor concerns are thus:
1. I notice a definite "flat spot" in the power band shifting into higher gears unless I keep the accelerator feeding new and larger amounts of gas to the process.
I installed a k&n air filter, new plugs, fuel filter, had rear differential fluids replaced with synthetic, and transmission fluid/filter changed. also replaced front rotors with brembos and hawk ceramic pads.
flat spot still there, and now it shifts hard into OD while cold, not as smooth as it was. When I got the car, it was silk smooth and CLEAN. Now, I'm thinking maybe the wrong fluids were used or something.
the transmission shop (good local reputation) thinks at most *maybe* one of the techs could have "nipped or pinched" an O ring putting the filter in, but need to leave car overnight for them to drive while cold. Not a big concern.
2. the factory amp was burned/blown, according to techs. I could only get sound out of the rear spkrs, and then extremely muted, no louder. had the stereo replaced to modernize with a "media center" and was told I'd need to find a factory amp replacement to get the rear subs (factory) to work.
I think therefore I need to find a factory replacement amp. Is that seeming correct?
3. the cable that drives the outer side of the LF seat is too short and comes out, disabling the back/forth movement of the passenger seat. I need a replacement cable. Does anyone know sources/resources for such?
4. the wheels of the previous (only one) owner were removed and cheapos put on, sixteens. My understanding is the car came with 17s on it & that it'll take all the way up to 19s no prob. is that correct.
5. the in-dash nav system: joke. in the first place it only had/has the MO regional disc in the unit.
The unit seems to think the lights are always on, and therefore I can hardly see it unless it's night. The display doesn't dim or brighten with interior light dimmer switch, only the lights around the unit's controls. It seems to function okay aside from that. I also can hear no sound/s from it whether audio CD or just letting the unit do its casual nav system whatever.
I have limited time available to get online, but I'm going to check back regularly to see if any answers or substantial help await me.
If anyone cares to, my personal eeeema il is jlrincu AT hotmail DoT com. what a car though, what a car, WOW!
rene v
