erich »
https://forums.nicoclub.com/erich-u2767.html
Sun Jul 27, 2003 5:55 am
Everything I know about the stock KA MAF says it runs out at about the same power level as 370cc/min injectors. 440cc/min injectors will saturate the MAF then you go lean, and then POOF! There have been some people who have hacked the S14 MAF with OK results, do a search for hacked MAF to see what they have done. I'd dig around in local wrecking yards to find a Cobra MAF as cheaply as possible for peace of mind. On a side note JWT says they only program for stock MAF, Cobra MAF, or Z32 MAF. As for injectors they said 370cc/min at 3 or 4 bar, 50lb/hr at 3 or 4 bar, or 72lb/hr at 3 bar. The 50 and 72 injectors are top feed (stock is side feed for KA24DE) so you will need a new fuel rail and pressure regulator.
