I've got a 300ZX with an RB25, not a 240SX. My radiator is substantially larger than a 240's stock rad. (If you were referring to me that is.. if not, sorry, ignore..)T4 RB25det wrote:really, the weight difference shouldnt turn you away from putting a new radiator in...
An RB30 block would be awesome, but since an RB25 barely fits I really don't think an RB30 will squeeze in at all. Besides that, I have no desire to pull the engine at this point in time and go that route, but I will definitely keep that in mind and maybe do it while I'm playing with the RB25. Where are some reputable shippers for shortblocks? I'm guessing you will need basically everything except the head for the RB30... ?T4 RB25det wrote:if you are going to upgrade pistons, you could simply buy an RB30 block from aussieland and ship it over for a total of around $500. rb30 blocks go for 3-$400. and then proceed with your build. that way for $500 more you just gained .5 liters of displacement and the rb25 head fits right on with no modifications.
Yes, I had forgotten about the cams. I haven't done my research on what type to use and what lift/duration/etc. I'm open to suggestions there but I haven't searched yet so forgive me for my ignorance. Along those lines, might as well throw in a pair of adjustable cam gears I'm guessing... ?T4 RB25det wrote:One thing you might want to think about getting would be a set of cams. Its going to be kinda hard to get 400hp out of stock cams.
Fito broke his because he used pump gas with a race fuel map and he was making closer to 600rwhp. Who's the other guy?rbsileighty wrote:He included 500 hp... which I assume means at the wheels... and from what I can recall 2 of the 25's on these boards have broken due to pistons at that power level.
Honestly, the only one I can think of is Fito's off the top of my head... can't remember who the other one is I was thinking of...eh? wrote:Fito broke his because he used pump gas with a race fuel map and he was making closer to 600rwhp. Who's the other guy?
Well... I was thinking about it some more and I'm still not convenced. So is this on pump fuel or leaded? With consistant pump fuel and daily weather that is the same as the day you tuned... ok... but unless you are tuning with each tank and every day... I'm not convenced they will last a long time at 500hp. I would be scared/uncomfortable pushing my 25 (if I had one) with 500hp even on a good tune. To many factors can go wrong... even with a "good tune."wawazat8402 wrote:I wont be scared to push mine to 500whp on stock pistons. The key is tuning.
Can you be a bit more specific than "good top end power"? Like what RPM range are we talking here..? I'm a bigger fan of a typical V8 style powerband of say... 2500-4000 max rather than a high-revving powerband like my S2000 has.. What are the 272's power band? Also, the adjustable cam gears are meant to adjust the timing, correct? If so, aren't they pointless with a standalone ECU like the PowerFC?T4 RB25det wrote:for cams if you want good top end power a 272 cam would work pretty good. cam gears should go along with that also, but not aboslutly needed. I am using stock cam gears with hks 272's
The engine bay IS deeper, however, there's a crossmember in the way.. heh..T4 RB25det wrote:the RB30 block is the same length as the rb25 but has a higher deck hight. not by too much. The 300zx has a deeper engine bay than a 240 anyway so at most if you wanted to run an rb30 you would need to notch some hood webbing. This swap is very uncommon in the states right now, but since its pretty cheap its going to become more and more popular soon. You would need the block and crank. get aftermarket pistons and i think rb25/26 rods fit. dont quote me im not sure.
Exhaust manifold I was looking at an SSAutochrome or an OBX unit, but after reading a few "disaster" threads about them.. I'm kinda sitting here wondering what to do... according to this forum, nothing bolts up to the stock manifold so I'm not really sure what I'm going to run for a manifold yet. I may just eat the cost and get an HKS or Greddy unit unless somebody has a better suggestion. The intake manifold I'm going to attempt to squeeze one of the Greddy units in if it will fit and I can find one, if not, I will just have to make my own.. Basically the manifolds will kind of be determined by the turbo I pick.. which will be based on price and condition.. Definitely a 70mm with a small A/R trim for faster spool, that's what I like based on other cars I've driven/ridden in.T4 RB25det wrote:what exhaust manifold are you going to be running? the stock unit will cause a great deal of lag because of its restrive design. What about intake manifold?
not on pump gas, there is a station a couple miles from my house with 110. also i have seen the local tuner that will tune this engine push other engines beyond what people have thought was safe. he is also very straightforward if he believes i may be pushing the engine too far. it should also be noted that my RB25 is not daily driven. It is only a weekend car for me, so the fear of it popping is not near as strong as it would be if it were my only transportation.rbsileighty wrote:
Top-end power is basically useless in the U.S. unless you live next to a high-speed ring. I'm guessing by top-end you mean 140+ mph and not top-end as in 5k RPM plus?T4 RB25det wrote:for an rb25 you are not going to find really good low end power and still have massive top end around 500 or so. In order to hit 500 you will need either a huge t3 flanged turbo or a moderately sized t4. Everything you do pretty much is going to increase turbo lag with the exception of new exhaust manifold.
Ok.. if the turbocalculator manifold is the SS Autochrome manifold, why are there two different sites for it and two drastically different prices??? Kinda weird.. Who makes the 'Phase 2 Motorsports' manifold and where can it be found? I didn't find it on a google search nor in the NICO forums anywhere..T4 RB25det wrote:As far as manifolds go i use the phase 2 motorsports one. it was the only moderatly priced manifold i could find that wasnt crap. A few problems were that the turbo hit the valve cover so i had to cut it and re-weld it so it would fit. Doesnt mean it will happen to everyone, i am running a rather large turbo.the turbocalculator manifold is the ss autochrome
Oh ok, I didn't realize you were referring to RPM for top-end. I expect to do a dyno run, and probably downgrade the turbo after that to get better spool.. but honestly I'm just going to give it a try first and see if I like it, and if I don't, then I'll deal with it from there. It's better IMO to go up and not like it than shoot too low and have to go up.T4 RB25det wrote:there are many different sites that sell the same manifold for differenct prices.phase 2 manifold http://www.store.yahoo.com/pha....html
by top end i mean rpm, not speed. you wont have good throttle response with a 500whp 2.5 liter
