setup plans!!
Post all your Nissan electronics, car audio and stereo questions here!
L0sT
i wanna know what you guys think about my setup! these were done in photoshop! lolwhat it would look like assembled (without stealth covers)
exploded view of setup (excluding the neon and blocks to hold upthe top layer)dont mind the amps, cap (if u can see it) and dist block, they are not to scale)
whiterps13
Car: white LE hatch
cool.. thats a good idea until you factor in your spare tire. and to be honest you arent going to need that big of a box for a 10 (which it looks like youre planning to run). let us know what equipment you plan on using...
L0sT
well, the box is already made, and it sounds really good (image dynamics YAY!!!)lol, and the box in the pic is not to scale either, i forgot to mention that.
looks like im going with a Lightning Audio 1 farad cap and a lightning audio fused distribution block (best buys i could find)
thanks, L0sT
whosurdaddy018
looks like your making it easy to be stolen
L0sT
hmmm, good point...maybe ill throw on a masterlock or two on the panel
thanks,L0sT
Simmsled
Car: TSI GTI - E46 325i
its a clean install, which I.D. sub are you using?
L0sT
idmax 10" dvc 4ohmxtant 6.1 600 watts maxLA 1 farad capLA fused distribution blockAlpine kac-628 amp for front speakers
Simmsled
cool. Those subs are beastly yet refined. nice choice. My roommate bought an IDQ-10 for its low frequency extention but the motor threw the cone outside of the surround's limits. The sub is not blown as the voicecoil is intact, but the surround is ripped so we are going to send it back for a new one.
L0sT
thanks man..but im in a pickle, i need suggestions on how i should cut the top layer to fit in my trunk. it has to be flush with all the sides because its gonna be the visible part. i got the bottom layer to fit in, but only after i had to cut it in half verticaly and then piece them in one by one in the trunk. It also has to be a lil bigger than the bottom layer because the sides of the trunk slant up at a slope. im not sure if i want to cut the top layer in half...
ayjay
trial and error... sorry man that's your only option :P best bet is to just get a huge piece of cardboard and make a template cause it's easy to quickly modify it with scissors... you could always just straighten out a metal coathanger and bend it into a shape that would best fit the area, but cardboard is much easier
