Postby
2005kyleo »
https://forums.nicoclub.com/2005kyleo-u72614.htmlThu Aug 02, 2007 5:22 pm
Hey im really interested in supercharging a 2005-2006 G35 Sedan but i have a tine a questions about the engine and its capabilities on how much it can stand up to.
I did some reasearch and looked into the Stillen Stage 3 kit. Then talking to a friend he mention that the G's 3.5 L is a high compression engine and it may not with stand something like that with out a set of lower compression pistons. The stock engine runs 10.6:1 and on stillen's website they sell 11.0:1 compression pistions and it notes not running a forced induction set up with them. They also sell some 8.0:1 compression pistions and its noted to run them with a forced induction setup. Im wondering with the stock setup being so close to the 11.0:1 pistons and it saying to not use with a S/C if the stock ones need to be changed out. Their Stage 3 kit does not mention anything about replaceing them and i figured if they should be they would make not about it. Also im not planning on adding more boost then what the kit gives. If i want to go more then i think it would be necessary to replace the stock ones to something less.
Next im wondering if the rods would be strong enough for the extra pressures in the combustion chamber.
Anyone know much with this? Any help would be awesome.
Thanks
BTW since i am a student in Nissans Advance Technical Training i have access to the factory electronic service manual. Willing to help anyone with something they need off it.
Postby
joe603 »
https://forums.nicoclub.com/joe603-u34652.htmlSun Aug 05, 2007 1:42 pm
2005kyleo wrote:You say all set ups can run on a stock engine if properly tuned. you mean like the right amount of fuel and octane or like reprograming the ECM?
Fuel = octane. I think you were refering to the air/fuel ratio.
A piggyback or stand-alone computer is what needs to be done. (Utech/E-manage are the two most popular).
The best advice is to take it to a qualified tuner to get everything right.
