Setup Help...pics please
Tx-Sx-FS
Car: S13 KA-T
i have a Garrett T3 Super60, i know i need the manifold, bov, injectors, walbro 255 fuel pump, fuel filter...what i need to know is if i HAVE TO to run an intercooler? do i HAVE TO to get jwt ecu or afc? if someone can help me with the actual piping and what they goto and come from (picture would be great) and what lines need to be run off the turbo, bov, or whatever...any help would be appreciated
Creature546
Someone told me if your going to spend the money on the project dont skimp out on things....you want a IC if you dont have alot of money get like a DSM side mount or something from a junk yard, and yes you are going to need something to control what you have added for fuel
Seth
hannibal
Car: Red Line to Glenmont
Definitely consider a IC, even an OEM side mount like creature said. You can run more boost with an IC.To control your bigger injectors, you'll need a piggyback (like SAFC) or a hacked MAF. I think you should search aroung here to find more about the hacked MAF. Its bascially a way to sneak more air by your MAF to compensate for more fuel from the injectors.
Tx-Sx-FS
Car: S13 KA-T
now that i know what i need to run at low boost safely...the piping is my next concern...i need to know what piping goes to what and etc....any info would be great...mainly ive seen some pics with the bov hooked upto the piping and some other stuff too...can anyone help me with piping and a follow through where the piping goes...pics please
fiznat
Car: Grown up :(
lol, here's a list for ya:
InjectorsFuel RailBOVForged PistonsExhaustTurbo Manifold: MSD 6al IgnitionBlow off Valve FlangeSpare KAEngine Stand Engine CraneTurbo Machine Shop WorkIntercoolerWastegateFuel PumpClutchFlywheelIC Piping, etcGasket SetTiming SetTurbo Oil Feed + ReturnIntercooler silicone connectors (x4)Gauge PodGaugesFuel Managment (E-manage in my case)DownpipeCat ConverterMAFSBattery Relocation KitBoost ControllerWideband Oxygen Setup Vacuum Distribution BlockTools (stands/jack/hand tools/etc)Misc Fittings/HosesAll new Fluids, etcReplace Parts You BrokeWelding Work30 Rack Beer + Pizza
haha thats everything that's on my list right now, and I'm sure I'm still forgetting a ton of stuff. Dont ever let anyone give you a list of like 5 things and tell you "thats all you'll need."
As far as an intercooler, I'd say it's definetly necessary. If you have to cheap out, then just get some bogus side mount or something- but get SOMETHING. I really dont feel like cooling is a place where you should skimp in a turbo setup..
If you dont know where IC piping comes from and goes to on a turbo setup, then you definetly have a LOT to learn - and probably shouldnt be buying parts yet. Go to http://www.howstuffworks.com and read the section on turbochargers, read this forum and for gods sake buy corky bell's book "Maximum Boost."
Tx-Sx-FS
Car: S13 KA-T
well i know that the piping comes out of the turbo to the intercooler back to the intake manifold..and one part goes from a air filter to the side of turbo...and the turbo sits on the exhaust manifold...but where would i put a flange for the bov to the piping?
fiznat
Car: Grown up :(
BOV usually goes on the cold pipe (after the IC), and then if you decide to re-route it, it feeds back to the intake after the MAF
Tx-Sx-FS
Car: S13 KA-T
ive mostly seen it by the turbo...but isnt that before the IC? im not sure thats why im asking..im trying to find a good pic but nothing yet...
fiznat
Car: Grown up :(
you can see the BOV on the cold side there, with the metal return line to the intake ;)
Tx-Sx-FS
Car: S13 KA-T
does that car not have an IC..im thinking about not Intercooling right away..just running turbo for a while...i can run at like 5 psi without damage i believe..so the other line coming off intake pipe going towards the intake manifold goes to what?? also is that little metal line coming off top of turbo, is that the oil return line or what?? and the blue rubber hose coming off the pipe going to bov is for what??
TurboKA37
1. that car is running an IC
2. piping coming off intake pipe going towards intake manifold attaches to the BOV so the gases from the BOV return through the turbo rather than going to the atmosphere.or you are talking about the other line which goes the the head which is the oil overflow i believe.
3. yes, oil return
4. pressure line so the BOV opens at the correct time
andrave
Car: 1989 Nissan 240SX Coupe
thats actually an oil FEED if I'm not mistaken...
TurboKA37
my bad.
andrave
its not a big deal, but he doesn't seem to know much about turbos so I didn't want him to get confused.
