zerothread?id=126070
you're going to have to use the Apexi wiring instructions in conjunction with your ECU Pinout Diagram (as listed in that thread)
The black and brown ground wires have to be connected to the SAME ground wire on the ECU, soldered 1" apart.
http://www.apexi-usa.com/pdfInstallation/18.pdf
on SAFC wiring harness
Red = power Green = TachGrey = Throttle Position SensorBlack/Brown = GroundYellow = Maf output TO ECUWhite = Maf input FROM MAF
on Car wiring harness
Power = Black/White wire pin # 38 or 47Tach = Yellow/Red pin #2 TPS = White wire pin # 20Ground = Black wire Pin # 39MAF = White wire Pin #16 (this is the ONLY one you'll have to cut)
(this information based off of This wiring diagram
Modified by Import_Ant at 8:26 PM 8/5/2005
