setting up greddy prfec b-2
MATT41178
Car: 92 NISSAN 240SX SE
Hello
I have just turbocharged my 92 240sx and I don't know how to set up my boost controller.
I have an external W.G
I want to run 10lbs in low and 15lbs in high setting.
does anyone have this set up on theirs?
98s14inaz
Car: 2010 Nissan Titan Quad Cab
It will be different on everyone's car. Everyone uses different sized wastegates and turbos etc. You have to play around with it until you figure out what % corresponds to which boost level. You might want to list your set up, hopefully someone might have something similar.
TurboSilvia7587
what if u have internal wastegate?
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
there should be a switch on the control unit that allows it to run with a internal wastegate or external wastegate. ( thats how the blitz one works ) usually with these electronic boost controllers is theres a volume knob. just start off at 0 and keep on turning it up until you start seeing a increase in boost pressure.
98s14inaz
TurboSilvia7587 wrote:what if u have internal wastegate?
Read the instructions, they are in english I promise. You need to swap the nipples on the selenoid for an internal or external wastegate according to the instructions.
MATT41178
I am running a t3/t4 stage 3, 38mm external WG, 50lb msd RFL bov and a big intercooler, does any one have this same set up
