itsa300zx »
https://forums.nicoclub.com/itsa300zx-u135155.html
Wed Mar 11, 2020 9:55 am
Stock sized injectors? 14-15 psi would be the most I would go until you have a dyno tune to know your engine limit, so 26% duty is fine for now.
1)Set the display to graph mode.
2)Set "start boost" to 10.0psi and do a run. look for boost spike at the beginning of graph, if none increase 0.5 psi increments until spike starts to show.(i'd guess around 12.0 psi or so ). "START BOOST" SETTING HAS TO BE LOWER THAN YOUR PEAK BOOST(ie yours is 14-14.5)
3)increase gain at small increments if the last 2/3 of the graph shows drop in boost. This feature is used to maintain boost.
For reference my hi boost settings 94 oct, 740 inj, stock turbos: yields 390 WHP, 405 Tq
70% duty for 16.9psi
start boost 12.0psi
gain 8
Every system will vary so you will need to play with it to fine tune.
