Setting TPS
Ca_Silvia
I did do a search all that came up is the proper voltages that the TPS needs to be. I cruised through the FSM and again all i found was the proper voltages.
So how do you "set" the TPS, because i took mine off and it got moved now my idle is ****ed.
ilovecoupes
You have to adjust it according to the FSM
the voltages should change when the throttle body, is opened, closed, or complete open throttle.
And you have to adjust the TPS in order to accomplish the proper values.
Ca_Silvia
OK i tried the multimeter on the TPS sensor. I couldn't get any values on the multimeter. I probed the wires at the sensor like:
12 +3 -
Is this right? From reading the posts that i searched this is what i thought was right, i also tried different combos and still nothing.
The multimeter was on Volts DC.
