Setting TPS Position
sicj
Car: 1987 Nissan 200sx hatch, 1992 240sx coupe
So I'm setting the TPS position per the FSM...
~1K ohms closed~9K ohms fully open
I have the closed setting at 1.03-- ohms, but at fully open it only goes to 7.7-- ohms.I can get 8.8-- ohms MAX from the TPS @ fully open, but then the closed reading is 2.2-- ohms.
So what's the verdict? Will this affect engine running? or should I try to get a new TPS? I have a KA24E TPS, could this work? Thanks...
wynnEZ
Car: 90 240 CA POWA!
I would also like some info on this, bump for you!
sicj
hmmm... maybe a few of you with running cars can do a quick test for information purpose that others can/could benefit from...then we can see what range we can really be in and be fine...
Here's the procedure:
sicj
It's a potentiometer inside the unit, so if the resistance gets F'd up in it you just get a new one... You set it by rotating it on the throttle body, tehn tighten the two srews to hold it after you calibrated it.
sicj
everyone scurred of electrical? no love?
