Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Sep 30, 2004 8:48 am
i've never disconnected my TPS, and the car accepts all the changes I give it.
Anyways, as long as your car is idling, and not revving, you shouldn't need to worry about the idle speed. If you set your idle speed to 2500, that would be different. I've checked my timing before when it was idling at 1100, and it came out fine.
What you're creating is a strobe effect with the light, and even with the light, it's not completely accurate. Also, all lights aren't created equal, so some will not read as well as others.
