Setting the timing on a 95 KA24DE
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
I'm going to borrow a timing light and set the timing on my 95 KA24DE, i believe it should be 20 degrees, is that correct? Then which of the marks is the 20 degree mark?
Thanks in Advance
98s14inaz
Car: 2010 Nissan Titan Quad Cab
If you are facing the engine it is the last mark on the right for the ka24de. That is 20 degrees btdc.
Ubernoober
Be sure to follow the proper procedure. The FSM will make it easy. As will a Chiltons, since they did a copy/paste right from the FSM.
98s14inaz
Make sure you unplug the tps first.
180fan
Car: 89 fastback
also make sure your motor is 1. warmed up, 2. after the warm up, adjust your idle to ~700 rpm with tps off.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
which plug is the tps?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
also where in the FSM does it talk about setting the timing?
