Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Sep 10, 2005 12:17 pm
you need to adjust idle, to affect the timing. You do not turn the distributor. The distributor isn't really a distributor on the 240, Nissan describes it as a Crank Angle Sensor, because all it does in respect to timing is send signals to the ECU saying when the distributor is at 0' or 180', and turn a rotor to transfer the spark in the cap. The cap and rotor would not need to be there if coils were installed on the cylinder, but there would still be the CAS. Long story short, you were not changing the timing when you moved the distributor, you were just changing when the computer found that the rotor was in a certain position. Then among other things, it found the position of each of the cylinders, and continued sparking where it was at. This is a blessing and a curse, because when installing a distributor you just need to be in the ball park, not perfect. But setting timing becomes more difficult. You have to find an adjusting screw on the side of the IAC motor, turn this screw to affect idle while the TPS is disconnected. Raising idle will advance timing. Be careful it is easy to make the motor ping this way, so listen for it. Continue adjusting (lowering idle) until you get to 16' BTDC, unless you want to retard it less for performance reasons. Once you are showing the right time w/ your light, shut the car off, plug the TPS back up. The idle will return to normal, because now the computer will be adjusting it. Double check your timing now, it should still be good, but you will want to know before you get sniffed again. Oh, and 9' BTDC is 7' advanced, I would say that is enough to cause some emissions problems. I would imagine particularly high NOx levels, but also some hydrocarbon. If anyone else would like to elaborate further, be my guest.
