I'm really starting to hate this Chilton's car-service manual. They combine the 240sx/altima in their explanations of things, except for the fact that they both have drastically different bodies, suspension, and the little fact that the altima's engine is mounted transversely vs. the 240's longitudinal coordination.
Anyway, I can't figure out the stupid books picture showing how to position the rotor to the no.1 cylinder. The figure says "when the dot on the distributor tang and the slit on the collar are aligned, the rotor is positioned at the no.1 cylinder terminal inside of the distributor."
I found dots, but I found many of them...I don't know which one they mean. I have no idea what a "tang" is, nor do I know what the "color" is, and I don't know what "slit" they're talking about. Damn!
(this is the pic from the book)
http://www.eniety.com/pichost/pic/121-2200_IMG.JPG
The next figure in the book says "after positioning the engine at TDC on the no.1 cylinder (which is where the engine is at right now), align the distributor gear to the marks on the distributor as illustrated. Then install the distributor. However, don't the rotor and the distributor gear both spin together? They do for my distributor! So if they do, can't I just align the gear and call it a day and install it?
Did I not disassemble this thing enough? Because it doesn't resemble their pictures at all.
Here's what it looks like...
http://www.eniety.com/pichost/pic/121-2199_IMG.JPG
and...
http://www.eniety.com/pichost/pic/121-2193_IMG.JPG
Is it not disassembled enough? It doesnt seem like I can't disassemble it any more.
Here's the distributor gear lined up to the slit in the distributor shaft, as illustrated by the book.
http://www.eniety.com/pichost/pic/121-2197_IMG.JPG
If the book says to make the distributor gear look like it does above when the engine is at TDC on the no.1 cylinder, then can I just set it like this and install it? I don't see why they have an alignment mark for the "rotor" and the distributor gear if they both spin together on the same shaft?!?
I keep confusing myself an unbelievable amount.
Basically what I'm asking is-HOW DO I ALIGN THE DISTRIBUTOR to the correct position to install it if the engine is at TDC on the no.1 cylinder? Should I align it like this pic
And assume that's enough? Because I can't find any alignment marks on the distributor rotor and the housing...
I promise this is the last set of questions (it better damn well be!)
Please respond asap--no one responded to my last post asking if all the links are lined up then it's alright...
ThanksMarc
