Setting New Timing Belt
nick22
Car: 1990 300ZX 2+2
Need advice on setting the new timing belt.
Before removing the old belt we noticed that with driver side cam timing marks on the sprokets matched exactly to the timing marks on the back cover. The passinger side cams were both one tooth before the timing marks on the back cover. We marked the exact location of the passinger side cams with a spot of paint on the back cover and removed the old belt.
We have the new belt lines set exactly on the crank and driverside cam timing marks. We are one tooth off on the passinger side cams.
Should we rotate the passinger side cams one tooth clockwise to line up with the timing marks on the back covers allowing the new timing belt lines to fall in place?
Or should we leave the passinger side cams in the position we found them and tension the new belt?
robomatic12
Car: 1990 300ZX TT
The dots on the back covers are just to help you get them close. What matters is the lines on the belt lining up with the dots on the actual cams. Make sure those are exact.
es.biggs
Car: 1990 300ZX 5sp NA
^^^+1
Double and triple check everything 5 times.
EVERYTHING! lol :yesnod
My timing belt job turned into a $700 (and still counting) rebuild
txQ45
Car: 91 300zx TT
Forget the marks on the back panel and count the teeth on the belt and align with mark on cam sprokets.
Re037
Car: 1992 300zx 2+2 NA
once the belt is on and your happy wiht it, crank it by hand a few times to make sure evrythign is clear before further reassembly.
