l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Sun Jul 11, 2010 12:53 am
OK, so you need to verify / set the idle and timing. Your tachometers accuracy is questionable. Read up and you will notice that the factory KA tach needs to be adjusted. You have a couple of options;
1. timing light with integrated tachometer.
2. Walk down to AutoZone / Advance / Pep Boys/ NAPA and pick up a basic SunPro or SW tach for $30, then rent a timing light if you do not posses one currently.
3. Send your existing KA tach to Carl H and have him modify it. Minimal fee, and you know it is accurately set.
Personally, I am not a fan of the integrated timing lights. I have seen them to be.. less reliable and accurate. Inductive timing lights work better, in my experience.
Also, consult is a great, free, tool. use it.
