Setting 240 at TDC on Compression Stroke
steamer1227
Car: 1995 Nissan 240sx KA24DE
yes a engine is made to contain explotions....but it is not made to have any obstructions during the process...hence .....internal compustion.....anyway if it works good for you but if your looking to get it done right and quick just look inside....
yeah if someone does search this thread and their cams are off then they prob got more probs than just setting the correct timing.
good luck
n
be easy
PapaSmurf2k3
Site Admin
that post doesn't make much sense... its pretty easy to get your cams off a tooth here or there...
"that's why they call it internal combustion"- wtf? They call it internal combustion because that's exactly what it is... not because it's not intended to have anything "obstructing" it.
Anyway to sum things up- Looking at the cams will only tell you if you are heading towards TDC on compression stroke or on exhaust stroke. If everything is set from the factory and unmolested, you are fine with this method.
steamer1227
internal combustion deals with fuel/air mix, spark........Not fuel/air mix, spark, and screw driver.
what i mean is someone might search this thread and put a small screw driver down in there and possibly drop it in.......im trying to save someone from f***ing up their motor for something that would be so much easier to do by looking at the cam.
"Looking at the cams will only tell you if you are heading towards TDC on compression stroke or on exhaust stroke."---is exactly what this thread was about....
if your off by a tooth the cams should still point the right way but if the cams are off by more then they prob wouldnt point right way.....
but you guys do what you want.
handinpants
Car: 240sx fast... powered by mice on a wheel.
there is a tool you screw in the spark plug socket and it whistles, when the whistle stops its at tdc
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Oh noes, I used a screwdriver and this is what happened
J/K, don't be a meat head and you won't have an issue.
PapaSmurf2k3
Site Admin
steamer1227 wrote:what i mean is someone might search this thread and put a small screw driver down in there and possibly drop it in......
Fair enough, but you should have said that instead of "it will score the piston".
steamer1227
i didnt say it would score the piston but i did say it would maybe cause damage or maybe not......
but hey we at least agree on owning a 240 right?
was that your piston for real....if so happened to it
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Camshaft broke and put all 4 valves in various places they shouldn't have been. Found one in the intake manifold
And now that I'm reading the original posting again, he just wanted to put the engine at TDC to take the head off so it doesn't matter if it's compression or exhaust anyway.
PapaSmurf2k3
Site Admin
steamer1227 wrote:i didnt say it would score the piston
Touche'
Got you confused with the other member.
Btw, 3 days ago I verified TDC with a screwdriver... and thought of this thread.
Mark- that sucks about your piston... this was mine after my valves hit it.
steamer1227
its all good.....BTW i was looking at your 240 and looks nice...i really like the KA-T.......i see the piston in your pic and didnt have time to research it but is that stock bore
PapaSmurf2k3
Site Admin
Negatory... .5mm larger, or .020"
steamer1227
nice how much did they run,,,,,who makes them.
PapaSmurf2k3
Site Admin
Supertech, and I'm almost positive they were $400.
