Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Fri Dec 10, 2004 9:16 am
not a good way to explain it to someone, red
to properly set the timing:warm engine to operating tempunplug throttle position sensor (tps)make sure idle is at 700rpms, if it isnt adjust usign the idle adjustment screw on the back of the intake manifoldhook up a timing light and point it on the crank pulleytiming marks on crank pulley go as follows-5, tdc, +5, +10, +15, +20 for about 8psi set it to +16 degrees, just a bit past the +15 markplug tps back in and your set
