Just went out and hooked up a spark plug wire to the #1 coil.... checked the timing--- Same reading. So I dont know about that whole double the reading thing.sideways danny wrote:the loop doubles the reading, check it by putting the inductive pickup onto the coilpack loom
Nothing, you should single out the trigger wire thou.c-rad wrote:But I didn't do it the way its described in the FAQ. It said to pull the coil and hookup a spark plug wire. I used the timing loop on the back of the harness and it worked. Its dead on at 15*BTDC. What is wrong with doing it this way?
