davskins97 »
https://forums.nicoclub.com/davskins97-u77287.html
Fri Jan 11, 2008 2:36 pm
I bought my O2 sensors for my '01 maxima at oxygensensors.com. If you buy the kind that does not have the plug on it (you have to cut off the OEM plug and crimp it to the new sensor) they are less than $50 each. There are 2 before the cat and 2 after. I replaced the 2 before at the same time. About 10,000 miles later I had to replace a rear so I did them both. I should not need any O2 sensors for my max again. Anyway, I bought the O2 wrench kit and the first install cost me about $125. Second time about $100. The job is easy enough that you shouldn't have to pay someone to do it.
