SES light confusion?
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
jbharris317
Car: Infinity FX 35
My 04 FX 35 has 87k miles and is a joy. My SES light has been coming on every week or so for the past couple of weeks, always with a different code? It came on two days ago, then just went out all on it's own? I'm stumped?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
What are the codes?
jbharris317
Car: Infinity FX 35
I can't give you the exact numbers but the first one indicated there was a communication problem in the system. The second one said there was a leak in the A/C system. But after reset, neither one has returned. Then, I had the SES light come on yesterday for a while, then it went out on it's own?
Q45tech
Have you ever drunk any liquids or spilled any liquids inside the vehicle?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Q45tech wrote:Have you ever drunk any liquids or spilled any liquids inside the vehicle?
jbharris317 wrote:I can't give you the exact numbers but the first one indicated there was a communication problem in the system. The second one said there was a leak in the A/C system. But after reset, neither one has returned. Then, I had the SES light come on yesterday for a while, then it went out on it's own?
It's a bit vague from your description but I have an idea of what you can do to fix this. What you need to do is remove the combination meter and tighten the ground on the interior bulkhead. There is also another common ground that should be retightened behind the glove box. If you need details on how to remove these things let me know and I'll get you some pictures and directions. It is not very difficult and requires a 10mm deep 3/8 socket a 12" extension ratchet and a phillips screwdriver.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Just take your FX to a reputable Infiniti dealership to have the codes interpreted and have the problems fixed.
psmwrx
do what stevethetech said to do that helps get rid of those comm codes
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
